Activity Forums Adobe After Effects Easing an Emitter on a Motion Path?
  • Easing an Emitter on a Motion Path?
    Posted by Max Jackson on October 13, 2012 at 7:14 pm
    Hi CC,
    I’m trying to ease something that looks like a tentacle going up a window.
    The thing is my tentacle was made in Particular and it’s motion is controlled by a motion path. I’d like to ease the motion so it slinks in quickly, slows down, and then quickly slinks out of the motion.
    However, sine there’s no keyframes I’m having a hard time figuring out out to control the easing of this motion. Time-remapping doesn’t seem to affect it either.
    Is there a simple way to do this?
    Matthew Keane replied 13 years, 11 months ago 3 Members · 3 Replies
  • Erik Waluska
    October 13, 2012 at 11:33 pm
    Hi Max, I get the result you’re going for but could you describe how you have this animation set up in a little more detail? The part about not having keyframes has me baffled.
  • Max Jackson
    October 14, 2012 at 3:10 am
    Hi Erik,
    I actually am figuring it out. To ease with a motion path you can use the motion path points in the motion editor to exact easing. I don’t know how this eluded me but I’m making some yardage now.
    That being said, I don’t think there’s a way to do Particular in reverse but I assume once I have the effect perfected I can make a proxy of the animation and then reverse it for the desired effect.
    Thanks for responding though! 😀
  • Matthew Keane
    October 14, 2012 at 11:32 am
    [Max Jackson] ” I don’t think there’s a way to do Particular in reverse”
    I’ve never tried this, but what happens if you set the Physics Time Factor to a negative value once you’ve reached the point where you want things to run backwards?
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
