Activity Forums Adobe After Effects Easily Write On Brush Strokes Sequentially?
  • Easily Write On Brush Strokes Sequentially?
    Posted by Donovan Keith on July 20, 2012 at 6:00 pm
    I’m trying to create an effect that builds up a drawing one stroke at a time. Basically, I’m trying to recreate something similar to all of those whiteboard lectures you see on youtube without the use of a whiteboard or video camera. Ideally I would do all of my drawing in after effects using the brush tools so that I have the power to remove strokes after the fact if I like.
    The “Write On” duration mode in the AE brush tool gives me an effect very similar to what I want. However, in order to use it, I need to draw a single stroke, advance the time slider to the end of the stroke, and then draw the next stroke. Is there a way to do this without having to advance my time slider each stroke? Doing so really interrupts the flow of drawing.
    Donovan Keith
    Donovan Keith replied 13 years, 11 months ago 3 Members · 5 Replies
  • Donovan Keith
    July 20, 2012 at 6:17 pm
    Okay so the following keyboard shortcuts are helpful but don’t fully resolve the issue:
    uu => Expands all animated tracks so that keyframes are visible.
    k => Advances the current time indicator to the position of the last visible keyframe.
    So the procedure now looks like:
    Paint a stroke.
    Press uu.
    Press k.
    Repeat
    Again, my goal would be to simply draw the image in one go and then have after effects rebuild it after the fact. Not unlike painting it in photoshop with a screen capture program running.
    I guess another option would be some sort of plugin that always advances the time slider to the position of the last keyframe anywhere in the layer would be helpful; but I don’t know if AE supports that sort of plugin.
    Donovan
  • Andrey Sibiryakov
    July 23, 2012 at 6:40 am
    Hi Donovan.
    You can press “u” instead of “uu” if it would help you.
    I think you’d better ask in expressions forum for some expression.
  • Donovan Keith
    July 23, 2012 at 7:01 am
    Hi Andrey,
    Thanks for the tip! With so many AE forums it was a daunting task picking just one.
    Cheers,
    Donovan
  • Ian Padgham
    September 26, 2012 at 10:33 pm
    Donovan,
    Did you ever find a satisfactory solution to what you were trying to do? I’m also experimenting with making a speed painting type image (like you see in Photoshop screen casts) but with the write on tool. I’d love to know if you came up with anything or found a good expression.
  • Donovan Keith
    September 26, 2012 at 10:44 pm
    Hi Ian,
    Unfortunately, I did not. I’d recommend just doing a screen recording in a painting app and re-timing the footage in AE or an editing program.
    -Donovan
