Activity Forums Apple Final Cut Pro Legacy Easily Moving Keyframes After Transition
  • Easily Moving Keyframes After Transition
    Posted by Ken Moscaritolo on December 15, 2007 at 7:38 am
    I have used FCP for some time and have learned ways around many editing problems. I still feel I am not efficient when I add transitions on keyframed material. The keyframes do not change and I need to go back and manually move these keyframes to the beginning of the transition. It sure is a waste of time! I bet I have to do this around 50,000 times a year, if not more. There are two solutions that I hope someone can teach me.
    1) A setting to dynamically move keyframes when applying transitions.
    2) A shortcut to this task, Highlight a clip, press a command that says “move keyframes to the new length of the clip.”
    This is what I need for Christmas.
    Ken Moscaritolo replied 18 years, 8 months ago 5 Members · 6 Replies
  • Chris Poisson
    December 15, 2007 at 3:34 pm
    Boy, join the club. Keyframing in FCP sucks huge. Best I can offer is use travel mattes, you can put your transitions on those and keep keyframes on you clips undisturbed.
    Have a wonderful day.
  • Arnie Schlissel
    December 15, 2007 at 4:18 pm
    When you add a transition if FCP, you’re effectively lengthening your clip to add the pre or post roll needed. I know of no application that will automatically move your keyframes when you lengthen or shorten a clip. Not AE, not Motion, not Shake, etc.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Larry Asbell
    December 15, 2007 at 11:31 pm
    [Arnie Schlissel] “I know of no application that will automatically move your keyframes when you lengthen or shorten a clip. Not AE, not Motion, not Shake, etc.”
    Avid always does, and Boris Red does it either way you set the preference.
  • Arnie Schlissel
    December 15, 2007 at 11:42 pm
    Interesting to know. Thanks.
    Arnie
  • Cody Alberts
    December 16, 2007 at 8:20 pm
    Have you tried keeping the keyframes visible in the timeline? If you hit opt-t it will toggle the timeline keyframes and you can adjust them right under your clip. the only other NLE that I know that has this option is Smoke…
  • Ken Moscaritolo
    December 19, 2007 at 4:17 pm
    I’m going to try to toggle keyframes. Thanks!
