Activity › Forums › DaVinci Resolve › Easiest way to raise and clip black levels?
  • Easiest way to raise and clip black levels?
    Posted by Nat Jencks on February 8, 2014 at 12:01 am
    There’s got to be a way to do this more easily… for a while I have been using a little trick where i put three nodes, one to clip blacks, another with a slight soft clip on black which makes blacks irretrievable, and then another which pulls blacks up.
    Anyone have a tip on an easier way (without 3 nodes) to clip and lift blacks?
    thanks
    -Nat
    Nat Jencks replied 12 years, 7 months ago 3 Members · 6 Replies
  • Juan Salvo
    February 8, 2014 at 2:35 am
  • Nat Jencks
    February 8, 2014 at 2:57 am
    Should have specified, I want to lift/clamp blacks more than is possible by simply using the traditional soft clip.
    I’m working with various 8mm and 16mm footage and frequently want to match the heavily clamped / lifted and tinted black levels of various Lo-fi transfers. I guess the 3 node method is it, just wishful thinking. I guess I could achieve this with curves but not ideal.
    I’d love to be able to leave the age exactly as is but raise / clip the blacks up to high levels…
  • Juan Salvo
    February 8, 2014 at 4:42 am
    You can get them pretty high by lifting the clip… there are two controls on the soft clips… clipping and softness. Raise the clip level and you can get a rather high amount of lift.
    https://JuanSalvo.com
    https://theColourSpace.com
  • Nat Jencks
    February 8, 2014 at 10:24 pm
    Understood, I’m matching some 8mm film transfers with quite extreme looks and need to really pull the blacks up. Thanks for the feedback, I’ll keep on doing what I’ve been doing!
    best-
    -Nat
  • Joakim Ziegler
    February 13, 2014 at 3:21 am
    Use curves.
    Joakim Ziegler – Postproduction Supervisor
  • Nat Jencks
    February 13, 2014 at 3:47 pm
    Yes indeed, curves work decently for this, but it takes a little patience to create a flat toe on the curve and ride it up and down to elevate or lower the floor…
    What I would really like is just soft clip but with more range to allow for more stylized looks (matching old vintage poor quality transfers).
    Honestly I’ll just keep using my 3 node approach w/ a soft clip to clip and pull values out of floating point.
    thanks everyone for the great suggestions.
    best-
    -Nat
