Activity › Forums › Adobe After Effects › easiest way to extract a frame?
Posted by Anonymous on August 18, 2005 at 10:37 pmwhat is the easieast/quickest way to export a frame as an image?
David Johnson replied 21 years, 1 month ago 3 Members · 2 Replies -
Jeff Herring
August 18, 2005 at 11:01 pmput your cursor on the timeline where you want your fram to be. then select “composition” menu and then “Save Frame as” and you can select the format (jpg,tga,gif) that you perfer
or
put your cursor where you want the frame to be and press ctrl+alt+s
David Johnson
August 19, 2005 at 3:29 amOr, get the free CopyImage plugin from https://www.obviousfx.com/
Then, put your cursor on the frame you want, Copy Image and paste into Photoshop of other program for editing.
