Activity Forums Adobe Premiere Pro Easiest Way to Create a Series of Videos
  • Easiest Way to Create a Series of Videos
    Posted by Dave Woodham on June 24, 2010 at 4:57 am
    I have a long video clip of a presentation that I would like to take clips from to make sort of a miniseries of short clips. Is there an easy way to create a template and just drop in the video and choose the clips that I want
    Alan Lloyd replied 16 years, 2 months ago 3 Members · 3 Replies
  • Jeff Pulera
    June 24, 2010 at 4:20 pm
    Hi Dave,
    You may be looking for “Sequences”. You can have multiple timelines (Sequences) open at once in Premiere, and can Copy/Paste groups of clips between them. For instance, you might want to break up your long video into several shorter “subjects”, so each subject can be worked on it its own Sequence independently.
    Just go to File > New > Sequence to create additional Sequences, and each of these can be renamed as well to stay organized.
    Note that for larger projects, it can help to not keep multiple Sequences open at once, if it is affecting performance. They can be closed, and will reside in the Bin until re-opened. Can be helpful to close extra Sequences, then Save, before exiting Premiere, otherwise it can cause Premiere to take a long time to open if many complex Sequences are open.
    Jeff Pulera
    Safe Harbor Computers
  • Dave Woodham
    June 24, 2010 at 5:03 pm
    Perfect – that’s exactly what I was trying to do. Is there a way to save a ‘template’ of a/v effects? Or does that just copy paste with my clips?
  • Alan Lloyd
    June 24, 2010 at 7:51 pm
    Create your beginnings and endings, titles, etc., and have them available for each sequence.
    Best to save those elements in a lossless format to avoid recompression.
