Activity › Forums › VEGAS Pro › easiest way to burn BD with DVDA-VegMStudio9
  • easiest way to burn BD with DVDA-VegMStudio9
    Posted by Alain Charlebois on March 29, 2011 at 7:02 pm
    hello subject matter experts ! ( I do mean this)
    just bought my blurayburner and want to re-render my VMS projects to bluray, but I want to save time 🙂
    I now need to get DVD architect 5 (as 4.5 does not burn BD) but with vegasmoviestudio 9 (platinum if this matters) I can render bluray and apparently burn directly to Bluray (not sure if menu BD thought)
    Questions:
    Which method is best ( directly from VMS or via DVDA)?
    If I create a menu driven BD with DVDA 5.0, is there a specific format to use which will avoid re-rendering (hence saving lots of time) ?
    Idealy I’d like a format that keeps the highest HD quality (my source files are from a sony HD 1080P camcorder) can’t figure if AVCHD or MPG will burn directly from DVDa.
    Will I have to render a second audio file (Ac3) like I used to for DVDs or is this now thing of thepast with bluray formats.
    thanks
    thanks
    Alain Charlebois replied 15 years, 6 months ago 2 Members · 2 Replies
  • John Rofrano
    March 29, 2011 at 11:32 pm
    [alain charlebois] “Which method is best ( directly from VMS or via DVDA)?”
    It depends if you want nice menus or not. VMS will simply burn the movie with no menus. Sort of like a VHS tape. You just put it in and it plays. DVD Architect will allow you to author a Blu-ray disc with menus.
    [alain charlebois] “If I create a menu driven BD with DVDA 5.0, is there a specific format to use which will avoid re-rendering (hence saving lots of time) ? “
    Yes, there should be templates under MainConcept MPEG2 and Sony AVC that begin with the word “Blu-ray”. These are the templates that you should use to make a Blu-ray compatible stream. Note: You will also have to render your audio separately as either PCM or Dolby Digital AC3.
    [alain charlebois] “Idealy I’d like a format that keeps the highest HD quality (my source files are from a sony HD 1080P camcorder) can’t figure if AVCHD or MPG will burn directly from DVDa. “
    Both will work. I usually use the one that matches by source. So if I shot HDV I’ll use MPEG2 but if I shot AVCHD I’ll use AVC.
    [alain charlebois] “Will I have to render a second audio file (Ac3) like I used to for DVDs or is this now thing of thepast with bluray formats.”
    Yes you will. This will keep your audio as high a quality as possible because you will be rendering directly from the original source.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Alain Charlebois
    March 30, 2011 at 11:58 pm
    thanks John
    Will try it out and get back if I experience issues.
