Activity › Forums › Adobe Premiere Pro › Easier workflow for adjusting variable light outdoors?
  • Easier workflow for adjusting variable light outdoors?
    Posted by Michael Kellam on November 10, 2015 at 7:54 pm
    I’ve been trying to adjust outdoor footage in a continuous shot where the light varies, sometimes dramatically. I’m using Premiere CC.
    I shot the footage on a GoPro Hero 4, which did a fairly good job adjusting to keep the shot from getting blown out, however the footage will sometimes look very low contrast (faded) and then within a few seconds, when the sun comes out, the contrast will increase dramatically, with the blacks becoming significantly darker and the whites in a few places reaching the upper limit and maybe a little above. (It was a partly cloudy day with clouds moving and the shot is a highly detailed forest with shadows and highlights sometimes appearing very close together.)
    I’ve tried a number of things to correct it so it looks more natural, but what seems to work best is a combination of shadow/highlight, brightness/contrast and 3 way color corrector. But I have 2 problems:
    1) Even though I’m using shadow/highlight on manual settings, when I cut a clip and then adjust the effects differently for both pieces, I have to use a 3-5 second dissolve so the change in effects is not visually perceived by the viewer. In some instances, this results in shadow/highlight flicker through the dissolve– (Just had a duh moment – should I be keyframing instead of dissolving?)
    2) Is there possibly a faster way to do this? I have 30 minutes of continuous footage and in many parts, I have to adjust every few seconds, which is a major headache. Is there possibly any more automatic way to accomplish this?
    Thanks in advance for any insight you might be able to share.
    Michael
    Michael Kellam
    https://www.kellammedia.com
    Michael Kellam replied 10 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
