Activity Forums Adobe Premiere Pro Easier way to extend markers?
  • Easier way to extend markers?
    Posted by Arturo Glass on November 22, 2017 at 6:37 pm
    Is there an easier way in Premiere to extend a marker? Now I’m having to double-click in the sequence, go to the Source window, option+click on the marker and then drag one side of it.
    The biggest thing I’m lacking, that I had in FCP7, was the ability to set a marker, continue playing a clip until I found a good “out” point, then have the extended marker snap to that playhead. In Premiere it doesn’t want to do that. Is there a simpler way?
    Arturo Glass replied 8 years, 10 months ago 2 Members · 2 Replies
  • Paul Neumann
    November 22, 2017 at 8:12 pm
    Markers work that way in Prelude where you can just hit O and it extends to the playhead even if it’s playing. Not in PPro.
  • Arturo Glass
    November 22, 2017 at 9:43 pm
    Thanks. And those markers can then be exported to Premiere?
    If I didn’t save the Prelude files I used when ingesting the footage, is there a way to import existing files into Prelude without having to re-render or transcode them?
