Activity Forums Maxon Cinema 4D Ease objects using Mograph
  • Ease objects using Mograph
    Posted by Adam Zygadlo on January 3, 2012 at 4:08 pm
    Hey everyone,
    Could someone lend any suggests on this. The idea is we see a group of text floating pass the camera and they gently settles down on the wall. (Slowing down onto the wall)
    The way I have approached it is making one effector: i) Shader; to control the position.
    Then in the ‘Falloff’ tab – I turned on the shape option to ‘box’, instead of ‘infinite’ and animate shader from left to right to make the object fall onto the wall. I adjusted the fallout number from ‘50%’ to ‘100%’ to soften the gradient.
    With the text (or objects) I placed them into the Fracture and linked it with the shader to take any affect.
    The problem I am having is, the objects isn’t really floating in softly but it abrupt onto the wall without any easing or slowing down. I have attached a basic mock up of the idea to show what I’ve done – 3486_boxassemible.c4d.zip
    So, have I missed something out?
    +Z
    Adam Jozef Zygadlo
    Motion Graphic Designer
    07708 124 915
    http://www.jarbrain.com
    ‘Filled with brainy goodness.’
    Adam Trachtenberg replied 14 years, 8 months ago 3 Members · 3 Replies
  • Brian Jones
    January 3, 2012 at 7:47 pm
    change the Falloff Function from Linear to Inverse Square or Inverse Cubic or try Spline and draw your own curve.
  • Adam Zygadlo
    January 4, 2012 at 12:14 pm
    Hey Brian,
    Cheers for that, it did the trick and looks so much better now! I thought there’s a option for the desire look! :^)
    Thanks for your time and Happy New Year!
    +Z
    Adam Jozef Zygadlo
    07708 124 915
  • Adam Trachtenberg
    January 4, 2012 at 4:56 pm
    You might also try adding a Delay Effector, which (in blend mode) adds a sort of automatic ease-in/out to mograph animation.
