Activity Forums Avid Media Composer Ease-in/out Problems on Image Resizing
  • Ease-in/out Problems on Image Resizing
    Posted by Dave Gordon on February 18, 2011 at 7:24 pm
    I’m just doing a simple “pan” move using keyframes and resizing. I’ve noticed that it defaulted to an ease-in and ease-out of the keyframe movement. I just need a simple linear move. We have Composer with Nitris working Sony HDCAM (but this particular effect is a JPEG photo). How does one shut off _or change the ease? There use to be an icon that I can’t find: _/
    I do not remember an “ease-in/out” default prior to eh Nitris upgrade.
    Thanks.
    Job Ter burg replied 15 years, 6 months ago 5 Members · 5 Replies
  • Jeff Gandillon
    February 18, 2011 at 7:49 pm
    They made a lot of changes to keyframes in recent versions of Media Composer. Not sure when the changes happened because I made a 10 year leap when we finally upgraded, but anyway…
    If you are running MC5 or a version with similar keyframes the easiest way I have found is to just right-click the keyframes. That should bring up a list of options for how to interpret the keyframes. In the cluster where “Spline” is probably checked change it to “Linear.”
    jeff g
  • Dave Gordon
    February 18, 2011 at 7:51 pm
    Thanks Jeff–I’ll give it a try.
  • Ed Cilley
    February 18, 2011 at 10:49 pm
    Another option, I love options…
    With the Effects window open, click the graph icon on the lower right. This will show you all your keyframes (and even the ones that extend before and after the clip – something different from previous versions). If you select all (CTRL-A or CMD-A), then right-click you will see the same menu Jeff was talking about.
    You will definitely be needing to find keyframes that are beyond the normal Effect window. If you copy effects from one shot to another and the duration is different, you can suddenly find shots drifting and wonder why? This is why.
    Hope that helps a little more.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Grinner Hester
    February 19, 2011 at 2:35 pm
    just put accelration at 0.
  • Job Ter burg
    February 19, 2011 at 5:03 pm
    There is no acceleration slider anymore. That was part of classic keyframes, whereas MC5 only allows for Advanced Keyframes.
