Activity Forums Maxon Cinema 4D Ease In to Linear (range mapping problem)
  • Ease In to Linear (range mapping problem)
    Posted by Corrado Carlevaro on July 22, 2019 at 10:59 am
    I want to write an Xpresso function to Ease In values at the beginning until normal linear interpolation, the very same way a car accelerates until it reaches constant speed, or the way you constraint 2 objects with a Spring Constraint.
    Spline graph in Range Mapper doesn’t work because at the end of spline mapping range there’s always an angle.
    In below picture I want to write an expression to get the blue curve from the green one (red one is range mapped)
    Any ideas?
    Corrado
    Corrado Carlevaro replied 7 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
