Activity Forums Apple Final Cut Pro Legacy E-mail FCP Project Files
  • E-mail FCP Project Files
    Posted by Alexander Lee on January 20, 2006 at 8:37 pm
    I’m having trouble e-mailing FCP project files back and forth between my editor. I’m using yahoo mail to send an attachment, and when the file is downloaded the icon appears as a white paper rather than the FCP clapboard icon. I look under “get info” and the file shows up as a “Final Cut Pro MEDIA file”, not an FCP project file. When I try opening the file in FCP, a message states “File error: Wrong type”.
    I know sometimes in the PC world that files will lose their extensions (.exe, .doc) and will not open until you manually type the extension in the filename. Does the same instance occur with FCP project files in the Mac world?
    Any info much appreciated.
    Alexander
    Here are system specs:
    Powerbook G4
    FCP HD 4.5
    Luke Asa guidici replied 20 years, 8 months ago 3 Members · 2 Replies
  • Gary Hughes
    January 20, 2006 at 8:42 pm
    Try zipping the file before attaching it.
    Gary
  • Luke Asa guidici
    January 21, 2006 at 2:12 am
    yes, it does
    try “.fcp”
    or after you have received the file, save it to your desktop, then highlight it and “get info” (apple + i)
    about 1/2 down the list there is an “open with” pull down menu – select “final cut pro,” and above that you can set the extension to “.fcp”
    hope that helps.
    …I’ll cut you up good…
