Activity Forums Sony Cameras E-error + restore media error
  • E-error + restore media error
    Posted by Enrique Orozco on November 28, 2009 at 6:44 pm
    OK …yesterday during filming a series of interviews and exactly when I press the Rec review button, my camera (EX3) doesn´t respond to the review clip command and then an E + some code appears briefly on the display followed my a restore media prompt (and the tally lamp begins to flash).
    The camera wasn’t recording when I press the Rec review button… in fact it was on “stby” for a moment (we were taking a “rest”) when I decide to check my last clip recorded …..
    What I did next, was turning off the camera, eject the media (MXR with 16 gig sandisk ultra), load it again, accept the restore media prompt that appears when I turn on the camera, and followed by a status bar working, all my clips were restored without a problem…. I just continue recording until almost filling the card (the problem happens maybe at half card) without any subsequent errors…
    Today I backup all my clips without a problem on my system…. as I always do…..
    I must say that I never have had a single problem with my MxR combos (almost a year with 2 of them) and as far as I can read this problems can occur as well with SxS original cards…. besides all my clips were fortunately recovered by the camera function itself….
    – Any ideas about possible causes ?
    – What about the E+code (don´t remember the code-numbers, it appears very fast and then prompts for media restore) ? … I just read on the manual that I must contact Sony service ….
    Any opinions from the experts would be greatly apreciated…
    regards
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Enrique Orozco replied 16 years, 10 months ago 2 Members · 2 Replies
  • Craig Seeman
    November 28, 2009 at 7:17 pm
    Error messages like that usually indicate a hardware issue with the camera. Call Sony and give them the error code. It may be a false report since the EX is really a computer after all. It doesn’t sound like it had to do with the card itself although the card was affected by the camera’s inability to do something.
  • Enrique Orozco
    November 28, 2009 at 7:50 pm
    Craig, Thank you so much… unfortunately and as I said before, the error code number doesn´t stay too long on the display, it was very fast and then the restore media message (which apparently solves the problem…)
    Anyway, I will call Sony and try to explain…. could it be a “possible” voltage variation ? (I’m using AB dionic with the adapter)…
    Thanks again…
    Enrique Orozco R.
