Activity › Forums › Adobe After Effects › e-card / newsletter
e-card / newsletter
Posted by Roger Burton on December 1, 2008 at 6:06 pmHi chaps I’ve been asked to make an animated e-card for someone to add to their christmas e-news letter. Can anyone point me in the right direction ie how should I deliver the finished job, as a flash file ? qtime movie ? and by the same token how do they create the mail-out (I can ask them this but would like not to appear too ignorant) – good of anyone to help me out here. Regards Roger
Merry Chen replied 12 years, 9 months ago 5 Members · 10 Replies -
John Hammond
December 1, 2008 at 6:20 pmThe best solution might create it all in Flash -small file size and good quality.
However, I don’t know flash so I might be tempted to create the video in After effects and export to .FLV, and then embed this into a Flash project. –Its hard to say without knowing what the client wants.
I think the best thing to do is ask the client’s technical people exactly how they will be sending it out.. as a PDF, HTML email.. link to a flash file.. or what? There’s a lot of variables and a lot to get wrong.
An example : I was asked to create a series of videos in AE with a lot of text. I made it to DV resolution as agreed. The client then wanted it to be embedded small on a webpage and also on a mobile phone. If I had known this I would of created it with this in mind so the text doesn’t get real small when it’s scaled down!
Roger Burton
December 1, 2008 at 7:25 pmThanks John, yes I need to talk to them but your comments have helped … I also don’t use flash (and don’t own it … too expensive) but I’ll find out a little more about their requirements. Regards Roger
Jeremy Allen
December 1, 2008 at 8:00 pmI work for a marketing firm and we do email campaigns all the time. We used to put Flash directly in the emails until we figured out that most people weren’t even able to see it. Most email programs disable Flash in emails by default. And most people won’t even know to enable it in their settings.
The best bet would be to send out a simple html email that links to the animation online. The final output kinda depends on what the client wants. Flash does have the ability to play H264 files now. In some cases you can get a smaller file size with better compression than an FLV. You could just post a simple qt movie online and be done, but it’s not quite as elegant or feature rich as Flash. Again, it just depends on what they want.
Hope this helps some..
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2
DualCore G5 2.0 GHZ, 2GB RAM, OSX 10.4.11AE CS3
Roger Burton
December 1, 2008 at 10:10 pmThat also helps a lot thanks Jeremy, It certainly makes life easier for me creating a H264 qtime movie in After Effects rather than Flash …. I’m guessing that when you say ‘not quite so feature rich’ you are referring to the clever tricks that can be achieved in Flash where the viewer can interact with the imagery by use of the mouse ?
Good of you to take the time …. regards Roger
Jeremy Allen
December 2, 2008 at 3:09 am———————————————
Jeremy Allen
December 2, 2008 at 3:13 am[Roger BURTON] “I’m guessing that when you say ‘not quite so feature rich’ you are referring to the clever tricks that can be achieved in Flash where the viewer can interact with the imagery by use of the mouse ?”
Yes, that is exactly what I meant. Also, when the ecard is done, it could say “Play Again” or give some other options, or start playing another vifeo, etc..
I did want to clarify though.. Flash can play H264 videos now, but the player would need to be coded for that, and the user would need at least Flash 9 to view it.
Roger Burton
December 2, 2008 at 5:44 amThanks again Jeremy, Adobe claim pretty good “Version penetration” of Flash 9 so, if their figures are to be believed that should be OK then … if you don’t mind me pushing my question further, if I prepare this as an H264 file is there a way of testing it (as if I were an end-user) or do I need to find a machine without Qtime but with Flash 9 ? (I’m sorry, I’m getting a bit out of my depth here) … thanks again Roger
Jeremy Allen
December 2, 2008 at 5:43 pmYou’ll just need to find a player that is coded to play H264’s as well as FLV’s.
This is the gold standard of free video players, and it supports H264 playback:
https://www.jeroenwijering.com/?item=JW_FLV_Playe
The documentation says it should be an H264 MPEG, but I’ve also had success playing H264 MOV’s.
Good luck!
Todd Morgan
December 2, 2008 at 9:08 pmYou could also consider an animated .gif file depending on how detailed the animation is. You could then embed the .gif right into the body of the email message and it would play on the receivers’ end.
Merry Chen
November 26, 2013 at 7:12 amhi, Roger, thanks for your topic, as to your problem, I just know such one useful guide for your reference: https://www.xflip.com/blog/creative-ideas-for-making-christmas-3d-photo-greeting-cards/
Hope it helps, good luck!
