Activity › Forums › Panasonic Cameras › E – 40 Warning Light
Posted by Bobby Holbrook ii on January 29, 2009 at 12:14 amHey guys
I have a HPX 2000 and I’m getting a blinking E – 40 in the display and the warning light is blinking. Any Ideas at all will help.
Thanks BobbyChief Editor/Cinematographer
P2 University Grad.
Holbrook Multi-MediaJeremy Garchow replied 17 years, 8 months ago 2 Members · 8 Replies -
Jeremy Garchow
January 29, 2009 at 1:30 amHmm, I think that might be a P2 warning, but let me look it up.
Jeremy Garchow
January 29, 2009 at 1:35 am -
Bobby Holbrook ii
January 29, 2009 at 2:29 amThanks Jeremy, I figured it out!!! I had the camera set for 480/24pN. But It can only shoot 24pN in 720p mode not 480i mode. So I changed it to basic 24p and TA-Daaaaa. Thanks… P.S.Silly question but is there any way to shoot 720p or 1080i in 4:3 Aspect Ratio???
Thanks Bobby
P2 University Grad.
Holbrook Multi-Media -
Jeremy Garchow
January 29, 2009 at 2:35 amWell, there you go. Didn’t even know that was possible to select those combinations.
You can’t shoot Hd in 4:3, but you can shoot 16×9 and protect for 4×3. You should be able to bring up guides in your viewfinder and on your monitor (maybe, not all monitors have that function).
What are you trying to do?
Bobby Holbrook ii
January 29, 2009 at 2:54 amLOL, I know!!! Well the client wants full screen HD shoot. As they put it “no black bars on the top or bottom”. So I’m left thinking aboot what to do. Any Ideas
P2 University Grad.
Jeremy Garchow
January 29, 2009 at 4:22 am[Bobby Holbrook II] “Any Ideas “
If they want full screen HD, then 16×9 it is (that’s full screen in HD).
If you mean they are going to show it in SD, then you need to shoot in HD but protect for SD like we talked about. When doing your editing, your monitor your program in from HD in SD with a center punch or center cut (or crop in Kona terms). I am sure you can bring up 4×3 guides in your viewfinder and if your monitor has it, you can do it while shooting as well (or tape off your HD monitor).
Make sense?
Jeremy
Bobby Holbrook ii
January 29, 2009 at 4:56 amGot it!!!! thanks
JeremyChief Editor/Cinematographer
P2 University Grad.
Jeremy Garchow
January 29, 2009 at 5:17 amWow, I really need to proof read. I’m surprised you got it.
let me try this again:
If you mean they are going to show it in SD, then you need to shoot in HD but protect for SD like we talked about. When doing your editing, you monitor your program from HD to SD with a center punch or center cut (or crop in Kona terms). WHile shooting, I am sure you can bring up 4×3 guides in your viewfinder and your monitor if it has that function. You can tape off your HD monitor if it doesn’t.
Sorry about the earlier jumble.
