Activity Forums Maxon Cinema 4D Dynamics Tag Question
  • Dynamics Tag Question
    Posted by Jim Zito on April 4, 2011 at 4:13 pm
    I’m using the dynamnics tag in the Broadcast edition of C4d and have a logo falling to the floor. I wanted to change the default speed at which it falls and make it faster so it hits the ground sooner…I wanted to give the object more weight. I tried increasing the custom density but nothing happens.
    Jim
    Jim Zito replied 15 years, 5 months ago 3 Members · 3 Replies
  • Ronny Traufeller
    April 4, 2011 at 4:26 pm
    increase mass of object or gravity of scene (edit –> project setting, modynamics tab)
    hope that helps.
    traufeller.de
  • Adam Trachtenberg
    April 4, 2011 at 5:07 pm
    If you’re using R12 you can adjust the time scale in Edit>Project Settings>Dynamics. That’s the most direct way.
  • Jim Zito
    April 4, 2011 at 10:48 pm
    I tried increasing the mass of the object with no success-nothing happened. Not sure why. But each of the other two suggestions worked, however.
    Thank you!
