Activity Forums Maxon Cinema 4D Dynamics tag animation issue.
  • Dynamics tag animation issue.
    Posted by Javier Lopez on November 28, 2010 at 2:50 am
    Hello there,
    I have an animation in Cinema 4D 12, breaking a logo into pieces using “Thrausi”, by animating the on and of dynamics switch, the logo is supposed to go back into it’s original state “Based on the “Fxphd c4d 204 Mograph and more tutorial”. I had followed their instructions but nothing happens, can someone please take a look to the scene file to see advise can be provided to correct the issue?.
    *Scene file here: https://f1.creativecow.net/1330/animation-test?uploaded=file
    Thanks in advance.
    Brian Jones replied 15 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    November 29, 2010 at 4:28 am
    The bits are not following gravity (which my first tests of Thrausi were all doing) which is odd but more importantly the return by turning Dynamic Off and On is supposed to be with an enabled cloner (type) object (I think, maybe wiser heads know better) and Thrausi turns the Fracture off. Maybe you will have to use a Random effector (or some such) with a falloff with an enabled Fracture object, then run the effector through the circle and cross to get the same kind of results.
