Activity › Forums › Maxon Cinema 4D › Dynamics question
Jim Scott
May 23, 2017 at 5:20 am -
Rick Morton
May 23, 2017 at 1:20 pmYup. I finally did that. I tried that first but must have done something wrong because I couldn’t get any thickness. I tried it again and it worked fine. Thanks for the response.
Din Iulian silviu
October 9, 2018 at 11:11 amHi.
I am trying to create a scene with dynamics objects. I encounter an error at dynamics.
I do not understand why after the first 100 frames, the keyframes does not still work, if I move the keyframe at start the animation it is working, if I move the keyframes after 70-80 frame, does not work…I attached here an example with what I do not understand:
How can I fix that?
Brian Jones
October 10, 2018 at 1:13 ama quick look and I can’t see what it is but just deleting the collider tag on cube.1 and the rigid body tag on cube in the f100 null and just reapplied them and it appears to work just fine
Din Iulian silviu
October 10, 2018 at 7:15 amI do not know how to explain, but I uploaded here an example:
So, why the cub hits the other cub if the keyframes are at first frames, if I move the keyframes after the 80-90F, nothing happen
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
