Activity Forums Maxon Cinema 4D Dynamics: Object inside other object
  • Dynamics: Object inside other object
    Posted by Lisa Schmölzer on June 7, 2012 at 3:21 pm
    Hey guys,
    I’m not really fit with dynamics and I’m trying to figure something out:
    I have two spheres. A large one, slightly transformed with displacement and placed inside an atom-array, to make it form a slightly irregular cage, and a second smaller sphere that I would like to put inside the larger one and have it bounce around as the larger atom-array sphere moves.
    The problem is: Cinema 4D still sees my larger sphere as a sphere (even if I convert it), having the smaller ball bounce of it, if I drop it from above, and completely going nuts if I place it inside.
    The same thing happens if I delete one side of a cube and have a smaller sphere drop into it, as if it was a open box. The Cube is still considered as a whole by the c4d dynamics.
    There needs to be a very easy to work around this problem?
    Thanks in advanced for any help!
    Cheers, Lisa
    Adam Trachtenberg replied 14 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 7, 2012 at 4:55 pm
    You need to set the collision type of the outer sphere to “moving mesh” in the simulation tag’s collision tab.
