Activity Forums Maxon Cinema 4D dynamics and in-points…
  • dynamics and in-points…
    Posted by Andrew Donaldson on February 17, 2013 at 5:53 pm
    Hi cow folks,
    This is really a general workflow question.
    How do you guys set ‘in-points’ like you would in a layer based application like After Effects.
    Normally I would set the scale to 0% then to 100% over 1 frame which does the trick.
    However in this case i am using dynamics and C4d won’t let you scale an object unless its at frame 0.
    (correct me if i am wrong here)
    I know the workaround could be to cut to another camera, but the project i am working on needs to be a single shot.
    The scene:
    I have a cell phone bouncing on a floor synced to music with the sound effector. There is a music cue where I need more phones to appear doing the same thing.
    Do you know how i set the phones to appear at a certain point in time?
    (like the in-point in AE)
    Many thanks!
    Andrew.
    Adam Trachtenberg replied 13 years, 6 months ago 2 Members · 2 Replies
  • Andrew Donaldson
    February 18, 2013 at 5:14 pm
    FWIW I found the answer:
    Apply a Display tag to the object and keyframe the visibility from 0 to 100% when you want to mark the in-point, or make the object ‘appear’.
  • Adam Trachtenberg
    February 18, 2013 at 5:43 pm
    You can also keyframe “visible in editor” and “visible in renderer” in an object’s Basic tab … fyi.
