Activity › Forums › Maxon Cinema 4D › Dynamics acts different in full render and software render/preview
  • Dynamics acts different in full render and software render/preview
    Posted by Oskar Westerberg on June 4, 2014 at 3:31 pm
    My dynamics doesn’t act the same way when I make a full render as they do in the preview. I’ve baked the dynamics, and they look right when I do a software render, just not when I do a full render. Can anyone explain to me what I’m doing wrong? I’ve googled for hours but the only “solution” I can find is to bake the dynamics, which doesn’t solve the problem for me.
    Software render: https://vimeo.com/97311765
    Full render: https://vimeo.com/97311764
    Oskar Westerberg replied 12 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Darby Edelen
    June 4, 2014 at 4:35 pm
    Can’t recreate your problem. Could you share the scene file so we can take a closer look?
    Darby Edelen
  • Oskar Westerberg
    June 4, 2014 at 4:49 pm
    Hi Darby,
    Sure, here it is: 7579_scen.c4d.zip
  • Darby Edelen
    June 4, 2014 at 8:47 pm
    There are no dynamics tags in that scene file. If you could also reduce it to just the parts that are showing the issue that would help.
    Darby Edelen
  • Oskar Westerberg
    June 5, 2014 at 7:43 am
    Hey Darby,
    Sorry I uploaded the wrong file :c Here’s the right file reduced to the parts that are showing the issue: 7582_test.c4d.zip
  • Adam Trachtenberg
    June 5, 2014 at 4:05 pm
    The dynamics cache won’t work for parametric soft body objects like your metaball objects. In order to make that work you would have to convert the metaballs into real geometry.
    If you want to try it without cache, and you want the render to look the same or more similar to the editor, you need to change the metaball settings so that those objects have the same number of subdivisions in the editor and in the picture viewer.
  • Oskar Westerberg
    June 5, 2014 at 6:15 pm
    Hi Adam!
    I tried ‘Make Editable’ on my metaball object, to see if that would work. But it makes the shape super detailed and way to heavy for my computer to do soft body on. Is there another way to convert metaballs into real geometry?
    Regarding your second advice, I’m afraid I don’t quite understand what you mean, how do I change the metaball settings in the editor and picture viewer?
  • Oskar Westerberg
    June 5, 2014 at 6:26 pm
    Oh wait! Yeah now I found what you meant “Editor subdivision” and “Render subdivision”. Yeah I did have different numbers there and now that I changed it, it seems to work. Thanks a bunch 😀
