Activity Forums Adobe After Effects Expressions Dynamically targeting layers with the index property
  • Dynamically targeting layers with the index property
    Posted by Sohrab Golestani on June 20, 2019 at 10:00 pm
    I have a .png that has been split up into a grid of segments using Utility Box v1.6 – each segment is one composition/layer. I want to scramble the image by rearranging the segments randomly. To do so, I rearranged the layers randomly, and I want to use an ease expression to move the layer from its existing position to the position of the layer under it:
    ease(time, 0, 2, value, thisComp.layer(index + 1).transform.position)
    This works great when I put it on layer 1 – it moves from its position to the position of layer 2 over 2 seconds. Great.
    When I copy that expression to layer 2, both layer 1 and layer 2 move to layer 3’s position.
    Is there a way to get after effects to evaluate the expressions independently?
    Sohrab Golestani replied 7 years, 2 months ago 2 Members · 2 Replies
  • Oleg Pirogov
    June 21, 2019 at 6:42 am
    You’re telling layer 1 to move where layer 2 is ([…].transform.position). So, since layer 2 goes to layer 3, layer 1 also goes there.
    Instead, you’d wanna layer 1 to go to former position of layer 2, so […].transform.position.valueAtTime(0) may be the solution:
    ease(time, 0, 2, value, thisComp.layer(index + 1).transform.position.valueAtTime(0))
    P.S. […](0) – zero here is “the time when layer 2 was at the position you want layer 2 to go to”. If it’s some other time in your case, you should change it accordingly.
  • Sohrab Golestani
    June 21, 2019 at 2:11 pm
    That did the trick, thank you!
