Activity Forums Web Design (WordPress, Joomla, etc.) Dynamically copy fields?
  • Dynamically copy fields?
    Posted by Sqrdreams on February 25, 2007 at 5:21 am
    Hello all,
    I’ve been looking all over for the answer to this question so I really do hope someone can please help me out. I just need a simple example of how to dynamically copy inputed values from a textField into a textArea by clicking a button. Someone suggested PHP and another suggested javascript. What I’m looking to do is create a small .css generator for my clients to use. This is the HTML I have so far. I placed *’s in it as I don’t know how to keep code from graphically displaying:
    <*input name="color" type="text" size="6"*>
    <*input value="Create Code" type="button"*>
    <*textarea name="output" cols="50" rows="10"*>
    <*/textarea*>
    If someone can give me a hand on this, or point me in the right direction, it will be very greatly appreciated.
    Sapphire Parker replied 18 years, 1 month ago 3 Members · 3 Replies
  • Curtis Thompson
    February 25, 2007 at 4:19 pm
    hello…
    ya – javascript is the tool that you need – i wrote a simple example and put it on my site for you:
    https://www.sitruc.com/cow/js_copy_fields.html
    you can get a lot fancier, but that should be the general concept you were looking for, yes?
    lemme know if not or if you have other questions!
    sitruc
  • Sqrdreams
    March 16, 2007 at 10:16 pm
    I’m so sorry it’s taken me so long to get back to you!! Life has become kind of hectic these past few weeks and I completely forgot about this post!! If Creative Cow has some way of sending me an email when someone responds, I sure do need to find it.
    I tried JavaScript and it’s is just way too confusing for me to learn at the moment. Hahaha. I did get this to work in php for the most part. Someone can input #FFFFFF into a text feild, hit the ‘Submit’ button and then receive the output code >color=#FFFFFF> to copy.
    However, when I try to place the output code into the box, the output code tends to come out incorrectly…it gets partially translated.
    If I don’t figure it out, I think I’ll just get rid of the text box altogether.
    Thank you so much for your help though Curtis!
  • Sapphire Parker
    August 21, 2008 at 3:11 pm
    Check out this code:
    <HTML><HEAD>
    function fn_move_2_textarea()
    document.getElementById(‘txt_textarea’).value = document.getElementById(‘txt_input’).value;
    document.getElementById(‘txt_input’).value = ”;
    </script>
    </HEAD><BODY>
    <form name=”frm_test” id=”frm_test” method=”post”>
    <input name=”color” type=”text” size=”6″ id=”txt_input” name=”txt_input”>
    <input value=”Create Code” type=”button” onClick=”javascript:fn_move_2_textarea();”>
    <textarea name=”output” cols=”50″ rows=”10″ id=”txt_textarea” name=”txt_textarea”></textarea>
    </form>
    </BODY>
    Cheers,
    SP
    https://www.videoediting-direct.com
