Activity Forums Adobe After Effects Dynamic Text Box Mask
  • Dynamic Text Box Mask
    Posted by Johnny Mabie on February 19, 2021 at 10:58 pm
    https://i.pinimg.com/originals/80/d8/2d/80d82deda7f6b9b671a4c2ddcf24242d.jpg
    Easily done in photoshop, but not so easy in AE.
    Effect can be seen best @ 1:36, as well as 1:30-1:33 and 1:46
    https://vimeo.com/481153884
    This is not simply masking the text layer or using a track matte, as the characters cannot be cut off, but rather dynamically fill the shape as it animates. I’ve tried using the text box/Path feature with a mask, but that bends the text lines and messes with the letter spacing, rather than keeping the lines perfectly straight, as you can see in the references.
    I’m assuming at this point that this is done with a third party plugin, as the Text Box Path feature seems pretty limited. Any thoughts??
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Filip Vandueren replied 5 years, 6 months ago 3 Members · 2 Replies
