Activity Forums Maxon Cinema 4D Dynamic text bounce wiggle inertia
  • Dynamic text bounce wiggle inertia
    Posted by Stuart Paciej on November 12, 2009 at 12:57 pm
    Hi there,
    I am trying to animate text so it (whole word) flies in to a determined position.
    When it hits this position i would like it to slightly overshoot, then as if on elastic bounce back past its original position and continue to do so until it eventually comes to rest on the determined position.
    I imagine this is something to do with Dynamics? also my text is generated using the Mograph text object.
    I am a total beginner to dynamics by the way!
    Thanks in advance.
    Stuart Paciej replied 16 years, 9 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    November 12, 2009 at 3:25 pm
    What you want is the Delay Effector set to spring mode. But don’t animate the text object itself. Instead, go into the text object>All>Transform section and animate the position there.
  • Tim Shetz
    November 12, 2009 at 3:32 pm
    Here is a link to a tutorial showing how to use the delay effector for the bounce effect:
    https://bit.ly/1SFmqy
  • Stuart Paciej
    November 13, 2009 at 11:26 am
    Thank you very much to the both of you, enjoy your weekends!
