Activity Forums Adobe After Effects Dynamic Particles? Move particles on impact with object?
  • Dynamic Particles? Move particles on impact with object?
    Posted by Moog Gravett on October 14, 2014 at 9:04 am
    Hi folks,
    I’m about to start playing to see if I can get particles being pushed around by an object. My foundation is to see if there’s a way, in particular, to have a static particle field that gets knocked about when something flies through it. I’m going to try using a solid as a collision object, then move it in 3d space.
    That’s the plan anyway, but I’m sure it’s not going to be as simple as that. So has anyone got any tips or ideas tat I can pick up on?
    Cheers,
    Moog
    Matthew Keane replied 11 years, 10 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    October 14, 2014 at 11:38 am
    Particular + Newton – these examples should give you an idea.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Moog Gravett
    October 14, 2014 at 11:43 am
    Thanks for the suggestions, I’ll take a look.
  • Matthew Keane
    October 18, 2014 at 11:39 am
    Not as realistic as Newton, but if you just need particles to be pushed out of the way, you could try linking the position of the Spherical Force Field in Particular to the position of your other object. It’s a quck and easy way to make it look as though particles are reacting to something.
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
