Activity Forums Adobe After Effects Expressions Dynamic orientation in dockable ui
  • Dynamic orientation in dockable ui
    Posted by Hadrien Ledieu on August 25, 2018 at 11:17 am
    Hi guys,
    I am fine tuning the UI (dockable) of a script and I can’t find a way to set the orientation of my buttons dynamically.
    What I want to do is quite simple, when the width of my window is smaller than the height, I want my buttons to be in a column. Otherwise in a row.
    I think I am quite close but it is not working.
    Would be great if someone could help me with this!
    Many thanks,
    H.
    function myScript(thisObj) {
    function myScript_buildUI(thisObj) {
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "My Panel Name", [0, 0, 300, 300]);
    res="group{alignment:['left', 'top'],\
    myButton1: Button{text:'1'},\
    myButton2: Button{text:'2'},\
    myButton3: Button{text:'3'},\
    myButton4: Button{text:'4'},\
    myPanel.grp = myPanel.add(res);
    myPanel.grp.myButton1.size=[30,30];
    myPanel.grp.myButton2.size=[30,30];
    myPanel.grp.myButton3.size=[30,30];
    myPanel.grp.myButton4.size=[30,30];
    myPanel.layout.layout(true);
    myPanel.grp.minimumSize = myPanel.grp.size;
    myPanel.layout.resize();
    myPanel.onResizing = myPanel.onResize = function () {
    myPanel.orientation = myPanel.size.width > myPanel.size.height ? 'row' : 'column';
    myPanel.layout.resize ();
    myPanel.onShow = function () {
    return myPanel;
    var myScriptPal = myScript_buildUI(thisObj);
    if ((myScriptPal != null) && (myScriptPal instanceof Window)) {
    myScriptPal.center();
    myScriptPal.show();
    myScript(this);
    Scott Mcgee replied 7 years, 12 months ago 2 Members · 3 Replies
  • Scott Mcgee
    August 29, 2018 at 1:10 pm
    I found this, as I was curious when I saw your post.
    I don’t know if there is a tidier way to do this, but this works. I tried breaking w.g up but it didn’t work. So you have something to start with at least that does work below.
    var w = new Window(“palette”, “test”, undefined, {resizeable: true});
    w.g = w.add(“group{alignment: [‘fill’, ‘top’], alignChildren: [‘fill’, ‘fill’], b1:Button{text:’b1′}, b2:Button{text:’b2′}}”);
    w.g.b2.onClick=function(){w.close();};
    w.onResizing = function () {
    var eps = this.size[0]
  • Hadrien Ledieu
    August 29, 2018 at 2:35 pm
    Thanks for this help but not quite the behavior I want…
    Here is what I am looking for:
  • Scott Mcgee
    August 29, 2018 at 3:00 pm
    Ah,
    Is that definitely with a jsx UI panel? I know you can do that with a CEP html5 dockable panel. I’ve not seen it done with a script UI panel though.
    Alternatively if it’s an AE plugin, I wouldn’t be able to tell you, but most are written in C/C++.
    Although I’m still learning the language, I’m working with html5 panels, which I can install with a .zxp installer. I can guarantee it works with that, but I don’t know with Script UI
