Activity › Forums › Adobe Premiere Pro › Dynamic link re-timed footage
  • Gabriel Regalbuto
    May 8, 2012 at 4:50 pm
    Seems particularly acute with over-cranked Red footage…
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
  • Alex Udell
    May 8, 2012 at 4:54 pm
    Constant or time remapped?
    might want to send non re-timed ftg to AE
    then retime in AE….
    Alex
  • Nevin Styre
    May 8, 2012 at 5:07 pm
    I’ve noticed this issue too & it happens 100% of the time, the only way is to leave clip alone in premiere & do the retiming in AE. Set your clip to the duration you want the retimed clip to be in your timeline, send the clip to AE so it creates a comp with the proper duration, then use the time remapping or speed options in AE.
    I also dislike when a clip is sent to AE from premiere that it doesn’t just create just a comp with the clip, it first creates a precomp of the entire source clip, then the composition you are to work on just has that precomp trimmed to your in & out choices. A lot of the time I would prefer it make a single comp with the source clip as the layer(at the right duration and in & out points sent from premiere of course). I think this is part of the reason that retimed shots from premiere don’t send properly to AE.
  • Gabriel Regalbuto
    May 8, 2012 at 7:13 pm
    Anyone know if this has been addressed in CS6? I’d jump on the upgrade to fix it, otherwise I think I’ll be waiting until I finish this job.
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
