Activity Forums Adobe After Effects Dynamic Link Problem, No clips show in AE Comp
  • Dynamic Link Problem, No clips show in AE Comp
    Posted by Dave Martin on October 17, 2012 at 5:37 pm
    I’m working in CS6
    This is driving my Nuts, I’m sure I’ve not changed anything recently as this workflow used to work but…
    Here’s the problem:
    1) I send a clip from Premiere to After Effects via the ‘Replace with After Effects comp…’
    2) AE opens and asks to save (No problem there)
    3) AE shows the comp with the footage in but, not in the correct position…
    – Let me try to explain that one.
    The footage IS there with it’s Premiere In & Out points set but, is like minus X Frames in to the comp – E.G. ‘-01:23:00:00’
    And so I have to go digging around, changing comp durations, etc. To find the clip, set In & Outs again and put it back at 0.
    I hope someone can help asap, as I’ve got a deadline to meet 🙁
    Cheers.
    Dave Martin replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
