Activity Forums Adobe Premiere Pro Dynamic Link PP-AE Timewarp
  • Dynamic Link PP-AE Timewarp
    Posted by Justinheaney on September 13, 2014 at 1:47 am
    Hi All
    Can anyone advise how to set dynamic linking of a premiere clip into after effects so that when you add the TIMEWARP filter in after effects via PP dynamic link process the clip doesn’t shift position?
    I realise there are work arounds involving manual input inside the TIMEWARP effect settings of the frames you wish to render out, but this is not what any of the tutorials on this subject show as needed…
    The tutorials I have seen (Lynda.com, Video Copilot) don’t seem to experience this issue or need to input frame values manually…
    Any help would be much appreciated
    Justin
    Justinheaney replied 12 years ago 2 Members · 2 Replies
  • Alex Udell
    September 13, 2014 at 11:44 am
    when you pass the clip to AE…
    take the layer in the in AE and Precompose it.
    then in the main comp (not the pre-composed one)
    do the timewarp. this way only the exact frames will be considered…
    hth
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Justinheaney
    September 14, 2014 at 4:22 am
    Thanks Alex.
    This speeds things up a bit
    Cheers, Justin
