Activity › Forums › Adobe Media Encoder › Dynamic Link:- Media Encoder > After Effects
  • Dynamic Link:- Media Encoder > After Effects
    Posted by Farhan Ali on May 15, 2015 at 12:27 am
    Hello everyone hope you’re well, I really don’t know what the issue seems to be as it was working find few days ago. I can’t seem to use Adobe Media Encoder to render projects from Adobe After Effects.
    For the past 30 minutes it’s been “Connecting to Dynamic Link Server”. Nothing has happened.
    What could have possibly gone wrong?
    I’m using Adobe Media Encoder CC 2014 & Adobe After Effects CC 2014
    Jeremy Weichsel replied 5 years, 4 months ago 6 Members · 6 Replies
  • Ryan Holmes
    May 16, 2015 at 12:24 pm
    [Farhan Ali] “For the past 30 minutes it’s been “Connecting to Dynamic Link Server”. Nothing has happened. “
    Sometimes it hangs. Simplest solution. Quit Adobe apps, and try again. Or you can quit Adobe apps, restart your computer and then try again.
    You can also clean out the Media Cache as I’ve found that sometimes helps:
    https://help.adobe.com/en_US/mediaencoder/cs/using/WSb8e30982e628fbec-54c04a521312559a5de-7ffc.html
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Ido Shor
    September 2, 2015 at 9:51 am
    same problem for me.
    it seems to got to do with certain projects. some works other don’t.
    no solution here..
    I.
  • Ido Shor
    November 25, 2015 at 6:34 pm
    Happened to me again this time I just disabled a third plugin I had (Sapphire Rack-defocus).
    and it worked…
    if anybody reading this still, might be helpful. 🙂
  • Mohamed ali Ben thaier
    November 12, 2017 at 10:53 pm
    Hi, I’ve encountered this issue to with AE CC2018 and the solution for me was to drag the .aep file into Media Encoder and select the composition I wanna render.
    I hope this would help
  • Denys Glagoliev
    February 3, 2020 at 3:37 pm
    To me – it helps to clean Cache
  • Jeremy Weichsel
    May 5, 2021 at 9:52 pm
    Media Encoder often has the same problem.
    What I’d like to know is, what exactly is the Dynamic Link Server?
    It seems like my AE files are being uploaded to a Adobe server before rendering. That makes no sense to me.
    Can anyone explain?
