Activity Forums Adobe Premiere Pro Dynamic Link is almost working perfectly
  • Dynamic Link is almost working perfectly
    Posted by Mike Behrens on March 30, 2008 at 2:53 am
    Hi there,
    I have read many posts on Adobe Dynamic Link on this forum, and they have been very helpful.
    I do have a question that I have not seen here though.
    I got Dynamic Link working fine. For example, I link my Premiere Pro clip to AE and add an effect like “Noise”. I save the AE project and then flip back over to Premiere and poof! The clip shows up with effects just as advertised.
    My problem occurs when I subsequently close the AE project. Then the clip shows as color bars in Premiere and the link seems broken. One funny thing is the color bars have the noise effect on them that I put on the missing clip.
    Because I have not seen this question here, I am thinking that I am either missing something simple, or there is something wrong with my rig.
    CS3 Masters Collection
    Windows XP
    Canon HG10
    Black Magic Intensity
    1920×1080 Square Pixels
    60i format
    -Mike Behrens-
    Bart Straman replied 18 years, 5 months ago 2 Members · 5 Replies
  • Bart Straman
    March 30, 2008 at 6:59 pm
    heey,
    ehm, what to do. save your AE project, close AE, then open it in PP2. then it should work fine.
    what you describe is I guess when you change in AE, it update automatic in PP2(dymanic link), than is very obvious that when you close that link it stops. only if you close AE (after saving) and import the AE project it should work.
    Bart
  • Mike Behrens
    March 31, 2008 at 12:11 am
    Thanks Bart, but that doesn’t work either. I have tried saving the AE comp and importing into Premiere, and as soon as I close AE, I get color bars in the linked clip.
    I have also tried, as you wrote, saving and closing AE before importing into Premiere, but I get the same result – color bars.
    Any other ideas?
    -Mike Behrens-
  • Bart Straman
    March 31, 2008 at 11:15 am
    heey,
    so if you saved your AE file, close everything and then import it in PP, it still gives weird color stripes, hmm.
    the reason those stripes appear is because it can’t find / display that particular file. if you double click on it it mostlikely gives a pop-up asking you where the file is right? (this is in AE, I also thought in PP). if you than find your movie file , than it should work. but normaly this shouldn happen when opening an AE file. mayby another reason is that the movie file is in some weird format PP can;t display it/handle it, mayby look at that to.
    Greetzz
    Bart
    ps: this is my discription of a few post a few years ago when alot of question came up for combining AE and PP
    Edit your clip in Premiere. than save your project.
    -open After Effects. file>import, then import your Premiere Pro project file.
    -now you see your clips in the project panel and very important a sequence file (it’s called that way I thought).
    -double click on that sequence file (important: do not move it into the timeline, just double click). and all your seperate scenes/shots/files (cut in Premiere pro) appear in the timeline in AE as seperated layers (also transitions and styles from Premiere PRo are imported).
    -then use coole effects on them separedly. if you wanne render in AE, your done here.
    render out in Premiere:
    -then save your AE file. and if you wanna render it out in Premiere pro, just open the AE project file in Premiere.
    -then only 1 clip will appear, but you’ve edit this the first time in PP and allready applied effects on it in AE, so no prob there 🙂
    i tried dynamic link, but this is only a options for 1 scene/dvd menu or whatever per sequence. only usefull if you wanne see direct result between AE and PP. not with a movie with 200 shots or so:P
  • Mike Behrens
    April 2, 2008 at 5:38 pm
    Thanks again Bart,
    That isn’t working either. I think that my computer is just messed up. I may be rebuilding it soon.
    By the way, I have read your earlier post on how you use Dynamic Link. In fact, that post was so helpful, that I have a printout of it right on my desk.
    So I just wanted to say thanks for that too.
    -Mike Behrens-
    -Mike Behrens-
  • Bart Straman
    April 2, 2008 at 6:15 pm
    heey Mike
    then it’s a very “rare” problem you have there. I still think it has to do something with the file location, but I’m not sure.
    dynamic link is very usefull and with the right steps switching between AE en PP2 on a bigger scale also.
    You know, you can render stuff out with alpha so that you can put cool and very stylish effects which you only wanna use to point things out in your footage. (in interviews, that in some fancy graphics the name of the persons display’s and then fades away,all that small things so you don’t have switch back and fourth for 10000 times from AE to PP2 with dynamic link/with the method I described and still wanna use al that good stuff from AE, rather then the basic things in PP2)you can read more about it here: https://www.videocopilot.net/blog/?p=151
    good luck with your projects!
    Greetzz
    Bart
