Activity › Forums › Adobe Premiere Pro › Dynamic Link caches keep going…
Posted by Dickij on March 28, 2006 at 3:43 pmHi
Anyone got any thoughts on how Dynamic Link is meant to work? It seems great that I can link clips in my Premeiere Pro 2 edit to Comps in an Afert Effects project –…BUT… if I tweak one of the Comps in AE it looses ALL the render cashes in Premiere from that AE project, not just the one relating to that AE Comp.
I thought this was going to be a great way to work but I’m not sure I like it if this is the case.
Any workflow tips, anyone?
Many thanks
JDickij replied 20 years, 5 months ago 4 Members · 9 Replies -
Steven L. gotz
March 28, 2006 at 4:38 pmThis is a recently discovered issue over on the Adobe forums. If any comp in the AE project is changed, then the renders disappear in Premiere Pro for all of the comps. Premiere Pro detects that the AE project has changed, not just one comp, the project itself.
The solution is to have one comp per project. That way changing one comp will not cause any other comp to need rerendering.
Dickij
March 28, 2006 at 5:01 pmThanks for the quick reply.
I’m not sure I’d be able to get my head around having lots of AE projects, one each effects clip in my edit, especially if I’d want them all to contain very similar elements.
Do you think Adobe will be addressing this at some point? It’s very nearly a great way to work but not quite!
Thanks again
Jamie -
Paul King
March 28, 2006 at 8:49 pmAgreed
You need to be able to select comps to import instead or projects.
However this will not solve using AE to despeck film. Everytime you add a brush stroke to the clip further down the TL, the earlier work will go unrendered in Premiere, which is workflow negative.
Paul
Steven L. gotz
March 29, 2006 at 12:25 amIt is a problem. But just “Save As” instead of creating a new comp. Or, just don’t render so often in Premiere Pro. After all, most video will play OK without rendering anyway. And you already saw it at full resolution in AE, right?
Dickij
March 29, 2006 at 8:56 amThanks, these maybe quite good work-arounds. I still think it’ll be a nightmare to work like that, compared to a single integrated piece of software where you can access and alter nested effects properly!
I thought an alternative way might be to render in AE and use ‘Edit Original’ if you need to tweak things after you’ve put the clip into Premiere. Trouble is that ‘Edit Original’ opens Windows Media Player instead of After Effects! I’m using BlackMagic .avi’s. Any thoughts on that one anybody!?
Thanks again
Jamie -
Jeff Bellune
March 29, 2006 at 7:45 pmIf you output from AE as an .avi file, then you can’t use AE as the target of Edit Original. AE knows how to open AE project files, not .avi files. AE imports .avi files, but it does not open and load them like WMP or Audition. Premiere and Encore won’t do it, either.
I know this may be simplistic and obvious, but I have to ask anyway. How do you organize your comps inside of the AE project that you are using? Have you tried organizing a series of AE projects insided of a folder in Windows the same way? The Windows folder would play the part of the AE project, and the AE projects would take on the role of the comps in the current project. If not ideal, it would certainly help you with the organizational details until Adobe changes the way that rendered previews are handled in Dynamic Link.
-Jeff
Dickij
March 30, 2006 at 9:33 amSo what you’re saying is that Edit Original won’t work with .avi’s even (when you use Embed Project Link when you render)
Jeff Bellune
March 30, 2006 at 12:10 pm[dickij] “So what you’re saying is that Edit Original won’t work with .avi’s even (when you use Embed Project Link when you render)
Dickij
March 30, 2006 at 1:27 pmOK. I’ll have to look into that. Good news if it is at least supposed to work!
Cheers
