Activity › Forums › Adobe After Effects › Dynamic link between two Ae projects
Posted by Rune Månsson on September 7, 2009 at 1:17 pmIs it possible to import one Ae-project into another and have it dynamicly update when changes are made.
Eg: I want an “Assets” project, where all my assets are placed, I then want to import this comp into multiple other project. The problem is, when changes and additions are made to the “Assets”-project, it doesn’t carry through to the projects that use the assets.
Is there any way to make this happen? It’s a real hassle to replace a piece of animatied gfx 42 places i 4 different comps 🙂
Regards
RuneGreg Hunsmezian replied 9 years, 6 months ago 7 Members · 10 Replies -
Rune Månsson
September 7, 2009 at 1:38 pmPlease be aware, that it’s “updating dynamically between projects” and not between comps in the same project, that I’m referring.
Todd Kopriva
September 7, 2009 at 3:56 pm> It’s a real hassle to replace a piece of animatied gfx 42 places i 4 different comp
If you’re just trying to update footage items (as opposed to adding/importing new ones), I’d think that you’d be able to accomplish what you want with this:
“To refresh footage items selected in the Project panel to use the current versions of the source footage files, choose File > Reload Footage.”
(from “Refresh footage items”)———————————————————————————————————
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Rune Månsson
September 7, 2009 at 5:15 pmI suppose that would be a solution, but for this project that’s not gonna cut it. The assets that I’m creating are 3D compositions, used i multiple projects but from different angles. So it would be really nice to be able to import them as 3D comps, that would dynamically update when changed in the source project.
But maybe no such solution exists yet.
Philippe Lessard
September 8, 2009 at 6:45 pmThere a way to do (sort of) this but i didtn recommend it because you need to keep the same name for different asset.You’ll have to duplicate the project you want to switch is asset.First, regroup all of the asset you want to overwrite in the project in a folder(in and out AE), then do the same with the asset you want to use(it work even if the asset are in 3d comp as long as they are the same size…etc)you’ll probaly have to move the original folder outside(just to make them offline) otherwise AE will find it and use it, so just rename your folder then use the copy of the project you just make then reconnect the now offline asset with the asset you want in.One project for each new bunch of assets.If you have a project that have hundred of assets you want to change quickly, that the way.
Rune Månsson
September 9, 2009 at 7:53 amDave>> Thanks for your answer, but I think I should have been more clear in my question. We are a team of four people working on this project. And we can’t all work in the same file at once. So the smart thing would be to split it up, but we don’t want to recreate the 3D for the icons in every single Project every time the client makes a change, since there are litterly hundres of icons to keep track of. And I know what nested comps are 😉 But thanks for you answer.
Phillipe >> I’ll try it out 🙂 Thanks
Rune Månsson
September 10, 2009 at 12:50 pmThank you again for you response 🙂 That is excatly the way we’re doing it now. Strict and stern rules about this and that. But man, would it be nice to have dynamic projects, so every body could relaxe a little 🙂 We’ve tride the disaster senario once before… not a pretty sight. Well, we can only hope that Adobe will implement such a feature sometime in the future. Thanks again for you replies, now I don’t have to test my sanity searching google.
David Cabestany
June 7, 2013 at 7:16 pm -
Chrissy Gonsalves
February 4, 2016 at 2:01 pmHas anyone figured out how to do this? I am working on a project with my co-worker and need his sections to update as he is editing. I imported his AE project into my AE project but it wont update his changes.
PLEASE HELP
Oona Switch
December 30, 2016 at 6:50 amhi – did you find a solution? I find myself in the same situation.
Greg Hunsmezian
February 2, 2017 at 11:11 amI am attempting to get around this issue by doing the project assembly in Premiere Pro. by dynamically linking the VFX shots my team mates are working on.
So far I have to say that the linked projects are very choppy in playback… but that may be just a server vs. video file size issue…
