Activity › Forums › Adobe After Effects › dynamic link and preview problem
Posted by Nida Ekin on August 2, 2011 at 11:19 amGreetings to you,
I have a problem but I have no idea whether solution.
I used dynamic link to work together premiere and after effects.
No problem with import. Problem is preview playback jumps around…
Is there a solution for this?Michael Szalapski replied 15 years ago 2 Members · 7 Replies -
Michael Szalapski
August 2, 2011 at 10:02 pmHow are you doing the preview playback?
What version of AE?
Whot operating system are you using?
What are your computer specs?
What kind of footage are you using?– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Nida Ekin
August 3, 2011 at 9:44 amI use space bar for preview basically…
AE and Premiere both CS4
I’m using windows 7 x64 and my system is -I think- power enough
8 GB RAM, 2,67GHz dual core processor (Intel Xeron)
NVIDIA Quadro FX 3700
I’m importing targa sequences to after effects and
then import to premiere using adobe dynamic link…
Please help… -
Michael Szalapski
August 3, 2011 at 12:57 pmYou didn’t say if you were using the spacebar in Premiere or After Effects, but either way, it won’t play smoothly unless the stuff is rendered already.
In After Effects, the best way to preview is to use the RAM preview. (More info here: [link])
In Premiere, you’ll have to render your timeline before it’ll play back smoothly.– The Great Szalam
Nida Ekin
August 3, 2011 at 2:31 pmProblem is in premiere preview…
“In Premiere, you’ll have to render your timeline before it’ll play back smoothly.” Do you mean render entire work area? -
Michael Szalapski
August 3, 2011 at 5:42 pmYou’ll have to render the part of your Premiere timeline with the AE in it. It has a red line over it in Premiere, right?
You can’t play back any After Effects thing in real time unless it’s been rendered.
If you don’t want to have to render things in Premiere’s timeline, I would suggest you render your AE composition out of AE and bring the resulting video clip into your Premiere timeline rather than the dynamically linked AE comp.– The Great Szalam
Nida Ekin
August 4, 2011 at 12:13 pmI’m working on a big project
no more effects but have to composit in ae…
so time is important for me.
Which one is fastest way?
But of course quality is important too… -
Michael Szalapski
August 4, 2011 at 1:00 pmAre you asking whether it’s faster to bring your AE comps into Premiere via Dynamic Link versus rendering out your AE comp and bringing the resulting video into Premiere?
I don’t know; you’d have to test it.– The Great Szalam
