Activity Forums Adobe After Effects Dynamic link (After Effect/Premiere) Error
  • Dynamic link (After Effect/Premiere) Error
    Posted by Malu Barreto on September 21, 2025 at 9:57 am
    I’m having a problem with Dynamic Link when exporting from Adobe Premiere to After Effects – I’ve always used the beta programs and never had any issues before. The versions I’m using for both programs are 25.6, as shown in the screenshot below. When I send the composition to After Effects, the program opens, asks me to save (as it always does), but no file gets imported.
    Does anyone know what the solution might be?
    estou com um problema no Dynamic Link para exportar do Adobe Premiere para o After Effect – sempre usei os programas betas e nunca tive dificuldade nenhuma. As versões que uso de ambos os programas é a 25.6 conforme o print abaixo.
    Quando eu envio a composição para o After, o programa abre, pede para salvar (como sempre) e nenhum arquivo é importado.
    Alguem sabe qual seria a solução?
    Mads Nybo jørgensen replied 12 months ago 3 Members · 2 Replies
  • John Martin
    September 21, 2025 at 1:17 pm
    hey Malu, no panic, it’s time to solve this, please, if you have a second, send a screen recording of the exact method you’re using so i can then suggest you the exact solution to your problem, talk soon!
    September 21, 2025 at 1:35 pm
    Hey Malu,
    John is the best and most likely person to help you here.
    I just want to ask: Why are you using BETA release from Adobe, when not even their v25.5 is stable?
    Maybe roll back to v25, if you can, and see what happens?
    Also, check what versions your Adobe Bridge and Media Encoder apps are at?
