Dynamic link: AE renders in PP not working
Being new to Premiere I decided to try out the Dynamic Link function to AE. As a test a sent a clip from PP to AE and then applied a time remap effect, basically a speed ramp from 100% to freeze, using pixel motion to interpolate the missing frames. When I returned to premier I found the updated clip as an AE project as expected, however when I rendered in PP I found the ramp to freeze did not interpolate correctly, giving me some repeated frames as it came to a stop. However on returning to AE and rendering out to a file as usual, and importing into PP, I found the frames were correctly interpolated, with movement in every frame as the video came to a slow stop.
Am I rendering incorrectly in Premier? (I created a work area over the clip and used the ‘sequence / render entire work area’ command.
Thanks! Ken.
