Activity Forums Apple Final Cut Pro Legacy Dynamic link
  • Posted by Dred33 Dred33 on September 30, 2012 at 2:21 pm
    I love FCP, i think that there are not comparisons with Premiere, but in the last one there il a very important plus:
    the dynamick link to use its sequences into the Premiere’s Time Line.
    So i have to create the clip con AE and then export them without compression and re-import the clip in Final Cut, but thereby i codify the file 2 times, and to make some changes i have to re-open AE and re-export.
    1-I can left AE to Motion (so i could import the sequenze in FCP Project), but i think AE is better and i know well it.
    2- With Boris plugin i can finalize the work into AE, but every times that i have to modify some little things i have to open Final Cut, modify and re-export.
    3- I could left FCP to Premiere, but… you know !! ;-D
    How do you work with AE and FCP? Exporting and Re-importing ?
    Shane Ross replied 13 years, 11 months ago 2 Members · 3 Replies
  • Shane Ross
    September 30, 2012 at 6:29 pm
    Yup. Always have to export out of AE as QT, then import that into FCP. There is no, and never will be, dynamic linking into FCP.
    Shane
    Little Frog Post
  • Dred33 Dred33
    September 30, 2012 at 10:56 pm
    And so? What you use to produce motion graphics, Motion or After Effect?
  • Shane Ross
    October 1, 2012 at 5:38 am
    Both. But I don’t produce that many graphics…I rarely do, and when I do I use templates, because that’s not my area. I hire graphics guys to do them, or…as I said…I use templates. But I use both. AE is easier for me to grasp when I do
    Shane
    Little Frog Post
