Activity Forums Adobe After Effects Expressions Dynamic Letter Multiplier Issue
  • Dynamic Letter Multiplier Issue
    Posted by Othman Ahmed on November 12, 2025 at 9:46 pm
    Is it possible to dynamically add extra characters to text layers based on a slider control. As a jsx which should work on selected text layers and allow me to animate the effect over time.
    So the core effect will be: Add extra characters after specific letters in the text
    For example: If I have the text <strong style=”font-family: inherit; font-size: inherit;”>”hello world”:
    • At 0% slider: “hello world” (original text)
    • At 50% slider: “hellooo woorld” (adds some extra ‘o’s)
    • At 100% slider: “hellooooo wooooorld” (adds maximum extra ‘o’s)
    Othman Ahmed replied 10 months ago 1 Member · 1 Reply
  • Othman Ahmed
    November 13, 2025 at 7:30 am
    I solved it with this expression:
    // Kashida (Tatweel) Removal Expression
    var originalText = “text here”;
    var kashidaChar = String.fromCharCode(0x0640); // Arabic Tatweel ـ
    // Get removal percentage from control layer
    var removePercent = 0;
    try {
    removePercent = thisComp.layer(“Kashida Control Layer”).effect(“Remove Kashida %”)(“Slider”);
    } catch (e) {
    removePercent = 0;
    // Find all Kashida positions
    var kashidaPositions = [];
    for (var i = 0; i < originalText.length; i++) {
    if (originalText.charAt(i) === kashidaChar) {
    kashidaPositions.push(i);
    // Calculate how many Kashidas to remove
    var totalKashidas = kashidaPositions.length;
    var kashidasToRemove = Math.floor((removePercent / 100) * totalKashidas);
    // Build new text by removing Kashidas proportionally
    if (kashidasToRemove === 0) {
    originalText;
    } else if (kashidasToRemove >= totalKashidas) {
    originalText.split(kashidaChar).join(“”);
    } else {
    var newText = originalText;
    var removedCount = 0;
    for (var i = kashidaPositions.length – 1; i >= 0 && removedCount < kashidasToRemove; i–) {
    kashidaPositions[i] = -1;
    removedCount++;
    var result = “”;
    var kashidaIndex = 0;
    if (kashidaPositions[kashidaIndex] !== -1) {
    result += kashidaChar;
    kashidaIndex++;
    } else {
    result += originalText.charAt(i);
    result;
    It’s working good, But I’m wondering if there is a better simpler mechanism?!
