Activity › Forums › VEGAS Pro › Dxtory causing Sony Vegas 13 to crash immediatly upon import – Lagarith Lossless Codec
  • Dxtory causing Sony Vegas 13 to crash immediatly upon import – Lagarith Lossless Codec
    Posted by Braden Mars on May 29, 2015 at 8:26 pm
    Hello! This is my first post on this forum.
    Anyways, I have game clip of CSGO recorded with Dxtory with the Lagarith Lossless Codec (.avi file). I pull up Vegas and move the clip into the program. The second the clip hits the program (vegas does not even show a video/audio track outline) the program crashes. To test the codec, I got Bandicam and set it up with the Lagarith codec and that worked fine. I also tried the default Dxtory codec, same results. From my testings I am led to believe its something with how Dxtory records.
    Thanks in advance.
    Braden Mars replied 11 years, 4 months ago 2 Members · 2 Replies
  • Steve Rhoden
    May 30, 2015 at 1:22 am
    Exactly, Vegas does not sit well with acquired files from Dxtory nor with
    some other NLE’s for that matter, problematic most times.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Braden Mars
    May 30, 2015 at 1:28 am
    Thank you for the speedy reply. Is this somehow computer specific or something? As in I just happen to not be able to edit dxtory videos on Vegas for some reason or another or is it fixable? I know many people use dxtory with Sony Vegas, in fact a very close friend of mine is doing everything the same as be except for he uses the default Dxtory codec, which as I mentioned before, I have tested. Once again thank you for the speedy reply and giving a peice of your valuable time to me.
