Activity Forums Panasonic Cameras DVX200 2-Slots Func Fail
  • DVX200 2-Slots Func Fail
    Posted by Ken Bennett on November 13, 2016 at 3:14 am
    On my new DVX200 I have the record function set to “2-Slots Func” – “Relay Rec” but when card 1 fills up it flashes “Card Full” and stops recording. Never switched to card 2. I’m shoot FHD 1080/59.94p 100M. Card 2 new a new card.
    Why isn’t this working correctly? What do I have set wrong?
    Thanks.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Josh Malyn replied 8 years, 4 months ago 4 Members · 3 Replies
  • Bernie Mitchell
    January 26, 2017 at 10:40 pm
    Ken
    Make sure both cards are the same. Class and speed.
    If you have relay set in the record function then it should work
    Bernie
  • Lindsay Simpson
    July 19, 2017 at 2:06 pm
    I have experienced this same issue with my DVX 200. I am using 2 duplicate cards (Speed and Brand) and I have the camera set to relay record. It will not automatically switch cards. I must enter hte menu and manually switch to the next slot.
  • Josh Malyn
    April 16, 2018 at 9:47 pm
    I was wondering if anyone has solved the problem with the DVX200 in relay mode not working with the two cards. I’m using SanDisk Extreme Pro 95/MB/s 128 GB SDXC cards and had the same problem. It just blinked “card full”. I thought maybe it was the fact that it was a SDXC card.
