Activity › Forums › Panasonic Cameras › DVX100B Audio Input 1 not working
  • DVX100B Audio Input 1 not working
    Posted by Kimba Kat on August 12, 2009 at 5:36 pm
    I have a DVX100Bp
    Whatever microphone I plug into Input 1..it does not work.
    Microphones work fine when I plug into Input 2.
    I noticed in the manual a “Phantom” microphone is discussed..but never defined. Is this my issue?
    thanks
    Tim Scarpino replied 17 years, 1 month ago 3 Members · 2 Replies
  • Micah Mcdowell
    August 12, 2009 at 8:20 pm
    Phantom power (also known as +48V) is required by certain kinds of microphones to function. These are generally wired condenser mics without batteries.
    If phantom power is turned off on input 1 and your microphone requires it to function, that could be your problem.
  • Tim Scarpino
    August 17, 2009 at 6:52 pm
    Are ure sure your mic/cable are working?
    If so, check the front of the camera to insure the mic/line switch is set to Mic and that your audio level knob is not in the complete counter-clockwise position.
    Tim
    Tim Scarpino
