Activity › Forums › Apple Final Cut Pro Legacy › dvx100a frame rate for ntsc and film
  • dvx100a frame rate for ntsc and film
    Posted by Paul Kondo on September 15, 2006 at 3:16 pm
    It seems the more I read, the more I get confused.
    I’ll be working on a documentary using a dvx100a. Because I’m an optimist, I’ll assume this doc will be seen by millions on video and film. 😉
    In the chance that this will get bought and released in the theatres and/or be shown on tv, I’m trying to figure out the best option to shoot in.
    I don’t know how footages gets transferred to the end product and what can be done to make those frame rate transitions. Is it easier/cheaper to shoot in 24p or 60i for potential outputs to dvd/video and film? What do filmmakers typically shoot in? Do I consider 24pa?
    Now, to make things a little more complicated, the footage may also be used by a 3rd party in India (PAL). I’m not so worried about that since that really is their issue/cost.
    Thanks in advance,
    PK
    Paul Kondo replied 20 years ago 4 Members · 5 Replies
  • David Roth weiss
    September 15, 2006 at 3:42 pm
    PK,
    Since it seems you haven’t started shooting yet I commend you for asking questions now. Many people in the same position are so excited to get out into the field that they wind up compromising their entire project from the very start.
    Let me suggest that you start by contacting the folks at https://www.filmout.com/. They will give you the lowdown on exactly what you need to do to achieve the best results for a filmout from tape shot on your dvx100 camera. They probably do more of this than just about any company in the business.
    DRW
  • Jeremy Garchow
    September 15, 2006 at 3:49 pm
    Yes, call filmout, but shooting in 24pA is the way to go as far as frame rate. That way you will cut in 24p and reduce your file size/bandwidth, You can make DVDs in 24p and going to PAL will be much simpler than in NTSC.
    Also, call filmout.
    Jeremy
  • Stu Siegal
    September 15, 2006 at 7:20 pm
    And add dvxuser.com to your browser bookmarks.
    In the meantime, here’s a link with some valuable info. Good luck, great camera choice, love mine.
  • Stu Siegal
    Always helpful to actually include the link.
    https://www.adamwilt.com/24p/
  • Paul Kondo
    September 16, 2006 at 8:39 pm
    Thanks for the all the help. I’ll give filmout a call.
