Activity Forums Panasonic Cameras DVX100 FW out to KiPro
  • DVX100 FW out to KiPro
    Posted by Tom Case on April 14, 2011 at 8:15 pm
    Anyone tried DVX100 firewire out to AJA KiPro? Is the FW out clamped? Will i get better than DV 25megabit bit rate on recording to SD ProRes via KiPro?
    Noah Kadner replied 15 years, 5 months ago 3 Members · 3 Replies
  • Steve Eisen
    April 14, 2011 at 8:53 pm
    You can not connect the DVX to the KiPro via firewire. There isn’t even an analog input.
    You would need an analog (composite) to HDMI or analog (composite) to SDI adapter.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Tom Case
    April 14, 2011 at 9:03 pm
    So the firewire 400 & 800 connectors on the kipro don’t function as input/output I guess?
  • Noah Kadner
    April 15, 2011 at 3:45 pm
    Correct those are for transfer to your computer as data, not Firewire video. KiPro is not really applicable to a camera like the DVX100 to be honest. It’s meant more for HD cameras with more aggressive compression codecs. At 25 mbit for just standard definition, DV is a lot closer to ‘uncompressed’ than most HD codecs in use today all things being relative.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
