Activity › Forums › Panasonic Cameras › DVX into FCP .. Q’s
  • DVX into FCP .. Q’s
    Posted by Ralph Watson on December 22, 2007 at 10:21 pm
    Hi all,
    I’ve just invested in a PAL DVX100B (I’m in England) and a Macbook Pro – installed Final Cut Studio 2.
    I need a run through on what’s the best process to capture the cam into FC and also what FPS I should be shooting in / editing at.. all the footage is for music videos so will be TV.
    Am I right in thinking that I should shoot in 24p – which is better: 24p vs 24pa? Also, if 24p is playable in all regions – why is there an issue with PAL vs NTSC and our differing standards? Wouldn’t 24p work the same in all cases?
    So far, I am guessing the following process.. please advise me on any points:
    1: Shoot footage in 24p
    2: Put DV tape into cheap camcorder for playback/transfer into MBP via Firewire 800
    3: Use external hard-drive to write to – connected by USB / Firewire 400 ?
    4: Edit inside FCP at 24p
    5: Use DVD studio to output finished film to DVD or…. whatever is required
    Is this right? I am new to this and don’t want to get anything wrong.. thank you for any help everyone.
    Noah Kadner replied 18 years, 9 months ago 2 Members · 1 Reply
  • Noah Kadner
    December 31, 2007 at 6:59 am
    Kinda moot- a PAL DVX100 shoots only 25p no 24p. So you would capture as PAL DV at 25fps- no pulldown issues to deal with.
    Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
