Activity Forums Panasonic Cameras DVX-100A settings for green screen
  • DVX-100A settings for green screen
    Posted by Elusivectw on May 17, 2006 at 2:10 am
    First of all, what is the best/easiest keyer to use for the dvx100:
    ULTRA2, dvGarage, nattress?
    Second, what are some good green screen tips to ensure I get the most out of my 4:1:1 dvx I possibly can? Any special cam or import settings?
    ctw
    Noah Kadner replied 20 years, 4 months ago 2 Members · 1 Reply
  • Noah Kadner
    May 17, 2006 at 2:16 pm
    Cam settings should be fairly neutral- you want thin Vdetail and don’t crank up skin detail or sharpness too much. The key to good composites in DV is really really excellent lighting. So make sure you have someone on set with lots of greenscreen lighting experience. A well-lit greenscreen is fairly easy to comp in DV. An adequately lit one is a nightmare. Here’s a good primer on lighting:
    https://www.vce.com/bluescreen.html
    Noah
