Activity Forums Broadcasting DVW-M2000 Digibeta Deck
  • DVW-M2000 Digibeta Deck
    Posted by Eugene Gordon on August 16, 2008 at 11:06 pm
    DVW-M2000 Digibeta Deck I am having a problem dubbing a tape out of a Panasonic-AJ-HD1400 to the DVW-M2000 SONY Digibeta Deck I have a signal and am good using SDI. The record inhibit will not go away I have even found in the menu and made sure it was off. I am still unable of manually Play and Record on the DVW-M2000 Digibeta Deck.
    Any ideas
    Eugene Gordon
    323-636-2039
    Din Noor replied 18 years ago 2 Members · 1 Reply
  • Din Noor
    August 26, 2008 at 1:31 am
    hI there,
    have you check on the tape itself?
    did you Press in the red record inhibit plug. (“ON”)
    Return this plug to its original position to enable recording on the
    tape again. (“OFF”)..
    thks
    Din
    be calm & patience.
