DVPRO 50 import question…
I borrowed a Sony PD150 to record my footage. Now I have to capture it to final cut using a Sony Handycam, an old one.
What settings should I capture on, the DV50 or just the standard DV NTSC48hz. All of this is NTSC, using Final Cut 5.
(Originally I imported with the PD150 but had Final cut set to DV NTSC, when exported it looked bad…)
thanks for any help or suggestions.
Alex
