Activity › Forums › AJA Video Systems › DVI vs SDI color space
  • DVI vs SDI color space
    Posted by Anhtu Vu on October 19, 2013 at 1:51 am
    HD footage are inherently rec709 color space. Now, if i playback my prores HD Mov file using a computer with an AJA Kona via its SDI output to a projector….i see the file in its native color space.
    If i playback the same file with the same computer but via its graphic card’s DVI output, does it mean the projector is now getting an RGB signal ??? as if i understand correctly DVI is only RGB.
    Anhtu Vu replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
